Putting it all together
Let’s bring it all together!
First collect the two linear rod supports and the two linear rod support tops.
Attach the tops using six nuts and bolts each.
Place the router assembly onto the sled assembly orientated so that the power cord lines up with the dust collection port outlet. (Picture coming soon)
Join the linear rod supports to the sled using six bolts each. There will be a small gap between the base of the upright and the sled initially, go around in a circle tightening each bolt gently to remove it.
Plug the two stepper motors into the controller board.
Plug in the power cord.
That’s it! Your Maslow4 is complete.
Next let’s learn how update the firmware, update the user interface, and run the calibration process in the User Guide.
Note that at the end of this step your belts will be partly extended. We will retract them using the automatic belt retraction function after we update the firmware.
Have any questions for find anything confusing? Ask in the forums and we’ll figure it out together!
